The following msg appears after I do the following:
1. add asset
2. add asset to titleset
3. click on added movie in titleset to preview
4. error msg
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040200): Exception from HRESULT: 0x80040200.
at DexterLib.MediaDetClass.get_FrameRate()
at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
at x3284ccece41ee22b.xb6dca8349e33d934.x8ab0d03b11b82 1b8(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.SideBar.9D(BaseItem 34S)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1900.43104
Win32 Version: 2.0.1900.43104
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA%20DEMO/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 4.7.0.0
Win32 Version: 4.7.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA%20DEMO/DevComponents.DotNetBar.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.QuartzTypeLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA%20DEMO/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA%20DEMO/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Results 1 to 1 of 1
Sony Vegas Webcam Recording Exception Error
By ventrino in forum Newbie / General discussionsReplies: 0Last Post: 16th Jan 2011, 08:50 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
error writting failed, exception 8, status 31 text'CstarBurn_ScsiTransport
By raiden68 in forum Authoring (DVD)Replies: 6Last Post: 6th Feb 2010, 00:39 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 14:15 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 03:53
