Is there a way to "reboot" my cable modem without physically walking downstairs, unplugging it then plugging back in? Is there a command I can run from my computer to restart it?
Results 1 to 16 of 16
Depends on the brand. You should be able to Telnet to it by IP address, but it is likely it will present you with a password field. More often than not, the password is the serial number on the bottom of the modem.
Never found a way to software reboot mine. I just unplug the PS to it and wait a few minutes. If you have to reboot very often, then you have a bigger problem.
the clapper..lol..it wont work between floors..seriously you can get a cheap remote contol ac plug.it does work.
glockjs has the right idea. You could use a X10 module and remotely disconnect the AC to the modem then reconnect. But really, why do you need to do it that often?
or invest in a man midget(monkeys work pretty well too) slave to do your biddings
Just run an extension cable up the stairs and plug the power into a receptacle close to you
I don't know how your service works but mine though dynamic does not reset the IP when you reset the modem. Regardless of extended power downs on the modem it's had the same IP for months. I think I've seen an IP change about 7 times in the two years I've had cable.
That totally defeats the purpose of dynamic ip's. They are supposed to go back into a pool to be redistributed when not in use.Originally Posted by Poppa_Meth
It couldn't be considered dynamic then, could it?Originally Posted by Poppa_Meth
I think maybe you are a bit confused... or have a static IP. -
Well it's suppose to be dynamic according to Adelphia and it does change from time to time, but not each time you reset the modem. I have no idea how they work it.
Me either, because if you reset the modem, you are supposed to grab a different number. How long did you power down the modem before?Originally Posted by Poppa_Meth
I had a power outage not too long ago. It was down for over 3 hours and still I had the same IP when it came back up. But Adelphia swears its dynamic. They charge you extra for a static IP.
ADVICE: Turning in dead cable modem
By Frank-0-Video in forum ComputerReplies: 6Last Post: 15th Mar 2010, 09:57 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 08:06 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 18:15
