    Dec 2004
    Is there a way to see if your DVDlab compilation is OK before you burn? After I burned I had problems with a section of the video. I can't tell if DVDlab is causing the problem or my burner. The file (VOB) is fine.
  2. What I do is compile in DVD-lab and then burn using a standalone burning program like Nero. What you can do too is burn to a DVD-RW and then if it looks okay on the RW disc, then burn it to a DVD-R.
    You can also compile the disc info to the hard drive, then use a program like PowerDVD to preview it on your PC before burning.
  3. Compile to the hard drive, test with a good software player, then burn.
    If DVDLab has a problem, it's usually because of mixed assets, or messed up connections.
    If the video plays, and the menu's work, but a portion of video is messed, then it's your source files.
    Just because it works on your computer, is NO guarantee it will work anywhere else.
    Cheers, Jim
    My DVDLab Guides
