Can I edit my DVD captured in 3:4 format to 16:9 without any distortion? Picture can be crooped, to fit to widescreen format, but I would prefare to play it with black bars on sides.I did not find any tools to do it.
The best way to do this is to set up your equipment correctly. If your TV and DVD player are properly configured, this is exactly how 4:3 should be presented. If it is not, I would suggest your TV is probably trying to play all incoming input as 16:9. It should be set to switch based on the source.
If you want to go down the crop path you need to resize the horizontal to 540, then add vertical borders of 90 on each side. Re-encode the result as 16:9 and author as 16:9. When played back, it will be a 4:3 box with vertical blacks and fit nicely. VirtualDub's resize filter will do the job nicely, then frameserve out to your encoder.
Note: the above figures assume NTSC format. For PAL resize horizontally to 554 instead.
You should really try to get your kit set up correctly first though.Read my blog here.
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 08:11 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
Authoring creates black borders on all four sides
By yurkyurk in forum Authoring (DVD)Replies: 4Last Post: 1st Sep 2008, 06:45 -
Black bars on sides of video...
By bla4free in forum Capturing and VCRReplies: 7Last Post: 1st May 2008, 07:55 -
WinTV PVR2 USB2 - Annoying Black Bars on sides.
By RedPenguin in forum Capturing and VCRReplies: 14Last Post: 15th Dec 2007, 18:42
