What are the suggestions of other members for a good dvd rom to go alongside this writer.![]()
Depends on what your criteria are.
You will undoubtebly want -R, -RW, +R, +RW and +DLRW compatibility and I would add to that region free firmware availability.
The latest drives from Pioneer and TEAC are good choices.
I still use my ageing Pioneer 116 DVDROM and have not yet found the time to replace it with a newer model. It still performs well, although it won't work well with +RW media.The more I learn, the more I come to realize how little it is I know. -
After going through the frustration of trying to get my 3520 to work in dma mode, including Compaq replacing the MB, only to find it was the dvd rom that caused it to not work, I just replaced it with another 3520 and updated the firmware and they both now read at 16x.
With good 8x media I can do a disc to disc on the fly copy in 7 min -
Lite-on drives are good and cheap and usually aren't speed locked.
Aopen 1648 AAP is a good drive and comes with no speedlock. Make sure you update to 1.02 firmware. Liteon 167T is a great choice as well and Liteons are speedlocked. Go here to get firmware to unlock.
http://codeguys.rpc1.org/firmwares.htmlStill a few bugs in the system... -
I personally use a Combo drive to pair up with my DVD writer. I have a Liteon 5232K in one machine and an Artek 52C16 in another and they both work great. They are also faster at burning CD-R's and handle copy protected CD's great. The price is usually fairly close between the two so I go for the Combos.
Originally Posted by chas0039
Other than the benQ 1620 after the speed read FW is put on.COPIED OVER 600 DVDS SO FAR
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 11:49 -
DVD-ROM Backup
By 329329 in forum Authoring (DVD)Replies: 2Last Post: 11th Mar 2010, 12:24 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 09:19 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03
