HI
I purchased Philips 642 DVP player and upgrade that firmware from Philips web site http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP642/37&scy=&slg=ENG&tmplt=...DVD_PLAYERS_SU , and after that I unlocked my Philips 642 to work for All Regions .
My question 1. is how can I know which DIVIX software is running right now in my DVP player is that 3.1 or 5.1 and is there any chance to upgrade that now or in future?
2. When will Philips 642 will work with qpel codec?
3. What is Macrovision?
4. Can Philips DVP 642 play Double Layer DVD+R 8.5 Gig?
Tanks
(1) It says in the manual which versions it will handle. Basically v3.x through v5.x will be fine. Possibility of upgrades exists anytime a new firmware is released.
(2) I'm pretty sure the chipset doesn't support it, so never.
(3) A form of copy protection... works by screwing with the analog signal, so for example you can't run a DVD player through a VCR to record DVD's...
(4) Dunno, this one will leave for someone else to answer. -
As to question 4, I would assume it isn't supported, although your standard store-bought dvd's are double layer, so I am not 100% certain. I still think not.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
