Nero is supposed to be able to do on the fly conversion from avi to VCD and then Burn or create image file(your choice). I am able to take a .mpg file in VCD Compliant form and burn to cd with nero just fine however if I try to let nero do the conversion on an uncompressed avi, it stops after the message 'encoding file' or something like that. The computer just sits there with the status window open with no writes to the HD and no Burn to the CD. Anyone else have this problem?
raka
Nope.
Try Nero V 5.5.4.0
Doing the same thing as you with AVI files, works no problems.
Poss. a nero problem as most nero's past v 5.5.10 have dvd, dvdr, dvdrw etc etc. support.
Any problems with nero 5.5.4.0 or above E-mail me direct, as getting quite good with it (Thanks to this site) !
Good Luck... -
Thanks er..Fatboy.
That was good advice. I tried the older version and it worked. I also tried the most recent version 5.5.6.4 and it works as well. There must be some bug in the 5.5.5.1 version that got fixed.
Thanks again
Raka
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 05:10 -
How to burn avi files using nero 8?
By funkymonk in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2008, 02:23 -
How to burn avi files to nero
By crocker5731 in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 21:13 -
Can someone tell me how to burn avi files with nero?
By trolea1234 in forum Newbie / General discussionsReplies: 13Last Post: 17th Jul 2007, 19:13
