I have the TMPGEnc Sound Plugin AC-3, but how do I use it???
Can I use it to convert between audio types?? I have some MPA & WAV files I need changed to AC3. Any help would be great
Results 1 to 14 of 14
Father knows best.
You can only "use" it when authoring DVD's.
If you simply want to convert other audio to AC3 (for whatever reason) get ffmpeggui.Cheers, Jim
My DVDLab Guides -
Change the files to wav with a sound editor such as goldwave or audacity and the go to program files/Pegasys Inc/TMPGEnc Sound Player and open TMPGEncSoundPlayer.exe and click on encode and choose dolby digital (ac3) encode/decode and drag the wav files to the left side of the screen and click on encode.
You can go into settings to change to bitrate to what you want.You dont need to use tmpg dvd author to use the tmpgenc ac3 encoding plugin.I think,therefore i am a hamster. -
I don't use this particular AC-3 plug-in (I have another "better" method with very "expensive" software) but I am curious as to what choices you have when using this AC-3 plug-in?
I guess you can choose the bitrate but do you have any other options?
BTW for a standard 2 channel PCM WAV audio file an AC-3 bitrate of 256kbps is usually "best".
I also suggest you "normalize" the PCM WAV audio file first ... before converting to AC-3 format.
With the plugin you can also use it to encode to ogg and use it as a equalizer/player with a playlist.In the tmpgenc dvd author environmental settings you can set the plugin to encode wav and mp2 automatically to ac3.
How do you Normalize?? I thouht I knew alot about this stuff LOL.Originally Posted by FulciLivesFather knows best.
You do that in your PCM WAV "editing" program.Originally Posted by dudeman316
For instance I use Sound Forge 7.0 these days but GOLDWAVE is cheap and very good as well.
I just started messing with ffmpeggui03c
It seems to do the job I needFather knows best. -
He is trying to adjust the audio for converting PAL format video to NTSC format video. The audio needs to be adjusted when you change the frame rate from 25P to 23.976POriginally Posted by johns0
Although with 5.1 AC-3 the new method of using DGPulldown is probably the best since no audio change is needed.
Apparently he didn't follow my link on that or didn't want to be bothered with it. Go figure
I am messing with a lil bit of everthing to see what is to my personal liking. Don't think I am ignoring you folks. I am not.Originally Posted by johns0
& FulciLives. I am not converting PAL to NTSC. I am just going from WAV & MPEG Audio to AC3 Audio. I am doing this because TDA wont allow one to mix the different audio types. It's picky. I have several titles I am trying to get into one Compilation & the audio differs.
Don't get me wrong, I am taking all info in... I am going to try the methods & software you all are recommeding...I figure you all know more than I do.. so why not listen LOL. Thanks all for your adive & recommendations. If you have more, please post I am trying to learn all that I can.Father knows best. -
Sorry. I been posting like a mad cow tonight and there are at least 2 other threads on PAL to NTSC that I have posted on and I simply got confused as to what thread I was on LOLOriginally Posted by dudeman316
Bro it happens, & BTW Fulci is the Zombie King LOL.
Father knows best.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
Converting WAV to AC3 - sound loss
By MackemX in forum AudioReplies: 10Last Post: 19th Mar 2009, 15:15
