Hi to All
I have a problem with getting disk burned with Deepburner to work in one type of DVD player It’s the Magnavox model MSD-124 when I use a disk made with Deepburner it will play just fine on my Daewoo S-5800 but not on the Magnavox I must be doing something wrong because the disk plays on the Daewoo. Any ideas on what I should try to fix the disk not playing.
Thanks for any Info
Dimoutlook
does it work if you burn with some other burn tooooool?
Yes it works fine if I make a ISO with DVD Shrink and use DVDDecrypter to burn the disk I just wanted to try a different way of burining.
Dimoutlook
