I am trying to burn movies onto a dvd to use on a standalone dvd player. Every movie I've burned a movie it plays fine on my computer but when I try it on my standalone dvd player the audio slowy becomes more and more out of sync with the video feed. When I stop the movie and replay it again the audio resets but goes out of sync eventually again. Lowering the burn speed helps but doesn't get rid of it.![]()
I'm using:
Windows 2000
WINAVI converter (convert to PAL because it seems to work better on my dvd player)
Standalone DVD player: Emerson 7002
Disk info: TDK Blank DVD+R 8.0x
Drive Information
Drive : SONY DVD RW DRU-710A
Type : DVD±R/RW DL Recorder
Firmware Version : BY01
Buffer Size : 2 MB
Date : ?
Serial Number
Vendor Specific : Aug06 ,2004
Drive Letter : F:\
Mechanism : Tray
Read Speed : 8.0 , 6.0 , 4.0 , 2.0 , 1.0 X
Write Speed : 8.0 , 6.0 , 4.0 X
Read CD Text : Yes
Return C2 Pointers : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : No
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD+R : Yes
Read DVD+RW : Yes
Read DVD+R DL : Yes
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read Digital Audio : Yes
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : Yes
Write DVD-RW : Yes
Write DVD-R DL : No
Write DVD+R : Yes
Write DVD+RW : Yes
Write DVD+R DL : Yes
Write DVD-RAM : No
Write BD-R : No
Write BD-RE : No
Buffer Underrun Protection : Yes
Mount Rainier : No
Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW DAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
Region Protection Control : RPC II
Region : 1
Changes User : 4
Changes Vendor : 4
Uhh... you're converting an NTSC disc to PAL, yeah? Depending on the method you use, yeah your audio will go out of sync - PAL operates at a different number of samples per second than NTSC.
Xactly my thought. Improperly done framerate conversion. As most PAL stuff play NTSC fine, it's rarely necessary to do this conversion.
What's your source material?
/Mats -
Yeah, normally PAL systems play NTSC without a problem, it's the opposite that isn't always true. But if you DO for some reason NEED to convert to PAL, you have to fix the audio and then do a framerate pulldown conversion.
There are guides... over
<------- there.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
