what would i have to do to transfer stuff between two xboxes, im trading mine for some one else, but he has some stuff on it he doen't wanna loose, is there a way i can transfer the stuff simple and easy between the both
Results 1 to 22 of 22
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Plug both into a router that is hooked up to a pc
i have a dsl cable router, ihave them both hooked up through the router, none of them are detected on my pc though, whats are you trying to tell me...holla back
You have to FTP to them via an FTP client like FlashFXP. Do you have Evox installed? Do you have IP addresses assigned for each Xbox? (check the settings option on the Evox menu). Input these IP addresses into your FTP client and file transfer until your hearts content.
this whole thing isn't working for me, cause i dont know what type of chip i hAVE, and i dont wanna flash it with something and f)(*&^% up my xbox, this is now my second guess, can i take out the xbox HD, then put it ion my comp, remove the files i need and then put it back in, all i wanna do is move these game saves to another xbox...holla back
If all you want to do is move your games saves if you can find an xbox to usb adaptor you can hook an external usb drive and move the saves to it then transfer to the new drive no modchip required for thisOriginally Posted by SIRCOOKS
www.llamma.com has the connectors fairly cheap
http://secure.llamma.com/catalog/product_info.php?cPath=27&products_id=254
or
If you take xbox with the stuff you want to save if its modded is do this
http://www.chefelf.com/xbox/networking.php
Save it to your pc then then just transfer it the same way back to the new one after its modded
or
If your drive is not modded then you need to download something like program to install a softmod or tsop flash save it to your memory card with a modded xbox and load up the exploit to the xbox with the info you want to save
Then use an exploitable game like 007, splinter cell, or mech Assult and then activate it and ftp the info to your computer then transfer to the new box after its modded
If I had it I could do it in less than 7 minutes and slap it on a cd -
thanks for your help, one last question though,im gonna go with the first option, because i have those xbox to usb connectors, whats the gui i need touse to transfer the files, or would my xbox just pick it up and allow me to transfer, my xbxo is modded, so would i have to cut on the modchip to do this...thats all i wanna know...how ould i copy and paste the stuff...holla back
You don't have to know what chip you have. It's enough that you have a chip. The easiest thing would be to either install Evox on your Xbox, but for two (both have to be chipped) it would be easier to just create a Xbox disc that boots the xbox to Evox. This will (if you have the xboxs plugged into a multi port router) allow the router to assign IP addresses to each Xbox plugged in. You then use this IP information, plus the username password combination in your favorite FTP client. Then, you can drag the game saves from one Xbox harddrive to your PC desktop (wherever), fire up the second Xbox, connect to it, then transfer the files from your pc to the second Xbox via FTP. It works sort of in reverse from backing up games (if you've ever done that).Originally Posted by SIRCOOKS
one other question, what type of cord or wire would i need for this, i have the adapters.....but what type of cord should i add on to the end of them
i just had to buy the dongle part, to add onto the adaptors, is there any other cord i can do this with..holla back
i tried all that ftp stuff last ngith, it doesn't seem to be working for me...holla back
what else can i use in replacement of this
http://secure.llamma.com/catalog/product_info.php?cPath=27&products_id=110&osCsid=a175...38697372a0b86b
or is this just the wire from the remote, in other words can i just get a broken remote and open it and get this type wire...holla back"If u cant eat it - u dont need it"
You just boot up your xbox as normal and then goto the memory option the xbox will see your usb drive as a huge memory card (if you are using an external usb hd or many flash drives)Originally Posted by SIRCOOKS
It doesnt matter if your xbox is modded or not with this
Think link that you pointed out above does not have the femal usb connector to stick a male connector into if you have a usb extender cable then you can just cut the lead and solder it to the cable that you pointed out in your link
The cable in the last link already has the proper usb female end so you can stick the regualr usb ext hd or flash drive up to it and its only $3.99 -
Did you use a cross over cable?Originally Posted by SIRCOOKS
Also try looking at the networking guide I posted -
thanks man, so if the lnik above is incorrect, can i just get a broken ciontroller strip it down and use the donglr from that...holla back..that was my origibnakl question
If you strip it down and if solder a female USB connector to the other end of it (a regular usb connector end wont work)Originally Posted by SIRCOOKS
Then you can use it with and external HD or usb flash device -
is there a website i can buy one from ,can u please dn me the url...holla back..ill buy it
could i unplug the dvd drive, install the hd,set it to slave, and it have the same effect for what im trying to do...holla back
http://secure.llamma.com/catalog/product_info.php?cPath=27&products_id=254Originally Posted by SIRCOOKS
this was the link in my first post -
Nope hd and mobos are tied together unless you have a chip but you would still have to ftp did you read the networking link above?Originally Posted by SIRCOOKS
that link isn't working please post again
goto http://secure.llamma.com/catalog/Originally Posted by SIRCOOKS
Look in the cables and accesories section
Poor Man's Xbox to PC USB adapter
The site might have had temporary problems the original link should work
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
transferring movies
By shashgo in forum Newbie / General discussionsReplies: 9Last Post: 15th May 2009, 09:18 -
Transferring From DirecTV to PC
By Hangrumps in forum DVB / IPTVReplies: 2Last Post: 9th Feb 2008, 09:20 -
Transferring viruses?
By Lucifers_Ghost in forum Off topicReplies: 6Last Post: 26th Jun 2007, 06:33
