  1. Member zoobie's Avatar
    Feb 2005
    Florida
    The Canopus ADVC-100 outputs analog. Other than that, are these units the same?
    Seems to me they are...but better double check.
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    From what I know yes.
    Also ADVC 50 and ADVC 55 are about the same on hardware
    La Linea by Osvaldo Cavandoli
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I was under the impression that the Canopus ADVC-100/110 handle "audio lock" better than the ADVC-50/55 but this is based on things I have read here not from personal use so I am not 100% on that.
    You might also want to look into the DataVideo DAC-100 as it is pretty much the same as the Canopus ADVC-100 but is cheaper and totally ignores copy protection as a default whereas the ADVC-100 needs a "trick" performed to ignore copy protection ... and said trick doesn't always work from what I hear. I don't think the other Canopus models (the 110 and the 50/55) can be made to ignore copy protection.
    - John "FulciLives" Coleman
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    Yes...I checked out the DAC-100 and read all the reviews I could. I noticed that many liked the colors better in the DAC-100 but a lot of people mentioned the great quality of the ADVC-100. Also, it was mentioned that the DAC-100 doesn't handle dirty sources as well as the ADVC-100.
    Toss up I guess...
    You may want to try your DAC-100 out on the new macrovision anti-copy code to see if it works.
    Same with the ADVC-100...
    We would all like to know the outcome.
    PS - I read to disable macrovision on the ADVC-50, you take off the #6 jumper...but now we need new results with the "new" macrovision.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    AFAIK the only definitive difference between the 50, 55, 100 and 110 is that the 100 & 110 units can output analog. AFAIK the 50 & 55 can't.
    If in doubt, Google it.
  6. All the Canopus converters use the same DV hardware conversion chip - the 50 and 55 don't have analogue out, but have the same A/D conversion quality.
    In theory the 55 doesn't support locked audio (the 50 does) but the word from Canopus tech support is that this is just a 'technicality' regarding the actual 'locked audio' spec, and that in practice the audio remains in sync, just like the other converters.
  7. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    This PDF has the most detailed comparison
    http://www.canopus.us/US/pdf/cc_br_advc_hz020704_WEB_PROOF.pdf
