Results 1 to 9 of 9
  1. I have just purchased a new Sony DVP-NC875 standalone player.The player is listed as being a region 1 player. I recently got a DVD that seems to have been produced in Asia. My PC plays it fine, When I try to play it in the sony I get this error (playback prohibited by area limitations). I figured I could backup the DVD and remove region or make region free. Well When I burned it with DVD Shrink, I selected Region 1 only, still doesnt play same error. I ran DVDInfo it shows DVD as multi region (1,2,3,4,5,6,7,8). Is this a bug in Shrink?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Are you sure your pc is REGION FREE? In other words your operating system should also be REGION FREE. Download DVD REGION KILLER, here is the link & use mirror 3 to download it.
    http://www.digital-digest.com/dvd/downloads/dvdrk.html
  3. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Just make it region-free, in Shrink, then you shouldn't have a problem.
    I've purposely encoded R0 films in R3 and R6 before, in DVD Shrink, to play on my NOVA 311 standalone, and I've never had a problem.
    - MJ
    (1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
    (2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
    GET MCSE HERE
    BenQ Ownz j00
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I tried to ensure that a DVDR was a Region 1 using the DVDShrink settings and mine came out as region free also. I thought that I had just done something wrong. Glad to see it is not only me.
    And making a backup Region Free is NOT the universal answer in some DVD players. SOME will only play a DVD with a region code....the same region code it is programmed for.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Some players will give a response like this if the format is incompatible (i.e. PAL instead of NTSC).
    Read my blog here.
  6. And making a backup Region Free is NOT the universal answer in some DVD players. SOME will only play a DVD with a region code....the same region code it is programmed for.
    What else could I use (besides shrink) to make a DVD Region 1 only. I use CloneDVD/AnyDVD for most of my backups but it doesnt let you specify region> AnyDVD wither makes it multi region or region free. Whats the difference. Anyway is there any other program to use?
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    The man is correct!!! Sony's are notorious for this message with pal disc's
    Even made region free, or more correctly, all region encoded.
    And as far as making a dvdr one specific region, i have yet to see it done
    8)
    I have been trying and looking for over a year, me and jimmalenko went through this once before,
    https://www.videohelp.com/forum/viewtopic.php?t=248261&highlight=
    use AVIcodec to check what the frame rate is...
    NTSC
    PAL
  8. Well the DVD in question works on my 3 year old apex which I hacked to be region free. So if it was PAL I dont think it would play would it?
  9. Banned
    Jun 2004
    Odd's are very high as apex's are also well known for converting pal to ntsc same as the cyberhomes.
    I even have a standalone GE player that i flashed with apex firmware to make it region free and it also converts pal to ntsc & vice versa.
