Not sure if this goes here or not but I am curious if the above mentioned Digital 8 camcorder supports video input via the A/V cable jacks or any other jacks? I am trying to record myself mountain biking via a lipstick cam and hope that this camcorder will support this and that someone on this forum has this cam or has had and knows the answer. Thanks
"ONE BY ONE THE PENGUINS STEAL MY SANITY"
Go to ---> http://www.sony.com/
Along the top you will see the word ELECTRONICS
Hover your mouse pointer there.
A drop down menu pops up.
Hover your mouse pointer over CAMCORDERS and another menu pops up.
On that menu select SUPPORT AND DRIVERS
This takes you to another screen where you select:
1.) PRODUCT ---> You pick DIGITAL CAMCORDERS
2.) SERIES ---> You pick DIGITAL 8
3.) MODEL ---> You pick DCR-TRV130
Then click on CONTINUE
This takes you to another screen where you will see the word DOCUMENTS (black text in a green bar).
Under that you will see a link called "Primary User Manual"
Click on that link.
An Adobe PDF file will load info your web browser. This is the "Primary User Manual".
yeah.. tried that before posting here... did not find anything about it in there about yes/no on input via the A/V jacks.
"ONE BY ONE THE PENGUINS STEAL MY SANITY" -
This says it doesn't.
http://photosig.pcphotoreview.com/Digital+Camcorders/Sony/PRD_96945_3100crx.aspx -
Originally Posted by ok_gsds
But then again I only briefly looked at the manual. I might have missed something.
That is why I posted how to get to it so you could read it yourself in-depth ... which clearly you did not.
Shame on you!
MPEGs recorded with Sony DCR-DVD108 not compatible with any video software?
By MarcosJP in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Oct 2009, 22:15 -
Transferring video from Sony DCR TRV 285E to PC ...need dv sample
By ganduman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Mar 2009, 09:20 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum Capturing and VCRReplies: 3Last Post: 2nd Nov 2008, 14:59 -
Pulling video off my Sony handycam DCR-DVD92
By briandk17 in forum MacReplies: 3Last Post: 22nd Jan 2008, 08:18 -
Recording video from external source? (Sony DCR-HC96 and others)
By kb1985 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Jan 2008, 17:46
