ok, i like to have menus cuz i watch a lot of movies before i go to sleep and having menus is nice cuz i like to go to a specific scene without having to haveto hit the skip forward button several times.
anyway, what i just thought of doing is taking the movie only with DVDShrink and encoding it to DVD format, open it with TDA and creating my own menus that are VERY small in size (like 2mb which is nothing on a DVD) compared to the actual DVD's menu which are usually 100mb+. The thing is DVDShrink's output is usually 4464mb which isnt the FULL size of a DVD so i can add 2-3mb easily (which will make the total like 4466-4467 which should still fit on a DVD5) without reducing the quality of the video but my question is, does TMPGEenc DVD Author reduce the video quality if i just re-encode the movie again adding the menu?
Adding chapters to DVD project in TMPGENC DVD Author
By robertazimmerman in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 10:09 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 19:53 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
