If your interested in picking up some test patterns, check this out. This guy normally sells them on his website for $50.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=3880670293&ssPageName=STRK:MEWN:IT
He also has a DVD version of it but it's in VCD format. Not sure why, I asked him.
Just about all of the test patterns are availble on the web. But be aware of copyright. There are 4 on the sample list that are not owned by him.
Just look up test card or test pattern on google. You could also look at Ham Radio ATV (amatuer televsion) sites. And yes I am a Ham Radio Operator, thats how I found this stuff years ago.
There is a program that have quite a few test cards built in and will cycle through them. It can be found on http://www.batc.org.uk/ under software. It's called PCATV.
Just remember, some of these images (Indian Head, resolution tartgets) were up to 3 feet across.
Anybody want a 16:9 colorbar and tone clip? 16:9 countdown leader with beep at 1 second?
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Greetings from Finland + my video test (HD)
By mazahito in forum Newbie / General discussionsReplies: 6Last Post: 17th May 2010, 01:21 -
870118 - finding similar patterns
By hamidi2 in forum AudioReplies: 0Last Post: 6th Apr 2008, 08:49 -
Video playability test.
By racer-x in forum Video ConversionReplies: 12Last Post: 27th May 2007, 05:13
