Due to circumstances I recently upgraded to Nero 6 OEM and all was going well burning DVDs until I found that I could not burn XVCDs as they automatically get re-encoded to VCD standard.
Now I have gone back to 5.5 as it seemed to be better all round, although 6 was better with DVDs.
What do Nero users think though - is 6 worth staying with or is 5.5 better?
Cole
For simply burning, 5.5 may well be a better choice than 6. But I've got 6.3, and as a whole when combined with Recode, Showtime, Nerovision Express, etc. the entire Suite of 6.xx is nice to have. For almost all my DVD Video burning I use DVD Decrypter, but I still usually use Nero 6 for DVD Data and CD burning, and it hasn't caused me any problems in that regard.
So I guess it depends whether or not you consider all of the great programs along with the burning program itself. -
For DVD it is TMPGEnc Plus and TMPGEnc DVD Author and then Nero to burn.
For VCDs and XVCDs it was TMPGEnc Plus and Nero 5.5. I will admit that I hadn't created an XVCD for a while (since moving up to 6), but did so yesteday - or rather I didn't as Nero 6 wouldn't allow it.
'Tis true though that the occasions where I make XVCDs are becomming rarer and rarer, so eventually 6 will take over.Cole -
I did try one of the free versions a while ago but because (and I was very much inexperienced then) it couldn't see any of my disc drives I gave up.
Maybe I gave up too quickly. Maybe I will give it another look, thanks
Cole -
You don't have to burn with VCDEasy - you can output to image file (cue/bin in VCDEasys case) that you then can write to CD-R/RW even with Nero.
/Mats
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
