Results 1 to 10 of 10
  1. I recently reformatted my computer using Win XP MCE 2005
    And I'm having trouble playing videos (mpeg-4s in particular)
    I installed all the codecs necessary (and confirmed it with g-spot) but I get a black screen when I try playing a video file
    I can view quicktime (.mov) files fine
    I have directX and my drivers for my monitor and vid card installed
    any advice would be appreciated
    thanks
  2. I just noticed that the thumbnail of the video shows the clip ...
    I dunno if that has to do with anything
    Mar 2003
    Kansas City MO
    Have you installed any DVD Player software yet? Have Power DVD or NVDVD?
  4. Mod Neophyte redwudz's Avatar
    USA
    You might try VLC Media Player. It should play most anything. It sounds like a codec problem. VLC would confirm that as it uses it's own codecs. If it works, then you might reinstall your codecs or see if one is interfering with another.
  5. thanks for the replies
    Nope haven't tried any DVD software yet...
    I tried the VLC Media Player but I still get the same problem -> black screen with audio
    sooooo I don't think it's a software or codec problem... hmm
  6. A guy from a different forum had a different problem. Apparently he resetted his bios and it worked.. but the same method didn't work for me...
    argh... someone please help!
    I turned on the machine last week to spend some time trying to fix it. Before it booted up windows it gave me a DOS looking prompt that said "changes have been made to the cpu and cannot boot" "press F2 to enter setup or Enter to restore factory settings" so I pressed Enter to restore factory settings just so that the computer would boot up. Well after it booted up I tried to play video and it works absolutely fine in Premiere, in Movie Maker, and every other player I have installed.
  7. any other ideas??!
  8. What kind of video card do you have? This happend to me along time ago ,the Video card was set to TV out or somthing like that,Play with those settings.
  9. I have a GeForce FX5200
    thanks, I'll try playing around with the settings
  10. hmmm played around with the settings... no go
