    Aug 2004
    Canada
    is tmpgenc plus better then tmpgenc? cuz the site states that the plus verison is the first verison of tmpgenc.... and that tmpenc got new features then the plus verison.
    so should i stick with tmpgenc then?
  2. I think that this is basically the same program except that with TMPGEnc Plus, it is paid for and can encode DVD and SVCD files after the 30 day trial period is over. Or would you be talking about TMPGEnc Xpress?
    What type of files are you making?
    Cole
  3. It would be helpfull if you stated which tmpgenc vs which
    IE TMPGenc Plus = Encoder
    TMPGenc DVD Source Creator = Encoder
    TMPGenc 3.0 Xpress = Encoder
    TMPGenc DVD Author = DVD Authoring
    TMPGenc MPEG Editor = more of editor Based on the MPEG Tool in TMPGenc Plus, not better or worse just different.
    Cheers
  4. Member daamon's Avatar
    Melbourne, Oz
    TMPGEnc, the encoder, is free and does MPEG1 with MPEG2 only being available in the 30-day trial period.
    TMPGEnc Plus, the encoder, is the paid for version of TMPGEnc and unlocks the ability to permanently do MPEG2 encoding = SVCDs and DVDs.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
