I got a file that is encoded .cdi. What codec would this use and how can it be converted to a DVD?
help
a .cdi file is most likely a discjuggler image file.
mount the cdi file with daemon tools, then you can access either the .dat or .mpg file on it.. if you want to know how to convert it, look on the left side of your screen. there are many guides.
