Hi all
I am interesting that while the one who watch the family trip
will be able, by one touch in the remote control to see a subpicture
of a map, where the trip is taking place.
Is there any way to do it besides an extra angle?
thanks
Shaul
I have an idea but it will frozen screen for a moment. It very intresting and will try to thing something
Bartosz -
Hi
Tomorow I''ll try to do this project and then I''ll tell You effects and idea (via e-mail). Even it is bad idea
Bartosz -
yes you can do it.
Just draw the maps in photoshop, using a simple 4 colour palette. (white, blue, red and black). Save each as a sequentially numered bitmap.
Now the next stage, is a little tricky. YOu have to make a scenarist script. something like this in your text editor.
now save it with a *.sst file extension.Code:st_format 2 Display_Start non_forced TV_Type PAL Tape_Type NON_DROP Pixel_Area (0 574) Display_Area (0 2 719 574) Color (0 1 2 3) Contrast (0 15 15 15) E2 (255 0 0 ===) E1 (0 0 0 ===) PA (0 0 255 ===) BG (255 255 255 ===) Directory E:\temp # # Palette entries: # # 01 : RGB(255,255,255) # 02 : RGB( 0, 0, 0) # 03 : RGB(255, 0, 0) # 04 : RGB( 0, 0,255) # ######################################################### SP_NUMBER START END FILE_NAME 1 00:00:10:07 00:00:23:06 ge.1.bmp 2 00:00:25:07 00:00:39:06 ge.2.bmp 3 00:00:40:07 00:00:53:06 ge.3.bmp 4 00:01:10:07 00:01:24:06 ge.4.bmp 5 00:01:25:07 00:01:40:06 ge.5.bmp 6 00:01:42:07 00:01:52:06 ge.6.bmp 7 00:01:53:07 00:02:06:06 ge.7.bmp 8 00:02:07:07 00:02:21:06 ge.8.bmp 9 00:02:22:07 00:02:35:06 ge.9.bmp 10 00:02:36:07 00:02:45:06 ge.10.bmp 11 00:02:46:07 00:02:55:06 ge.11.bmp
E2, E1, P and Bg refer to the 4 colours you used in your bitmaps, and the directory is the directory where you saved your bitmaps. If you are in NTSC format, then you will have to adjust the pal frame sizes to the ntsc values.
Now, in your scenario, import your subtitle script, it should import the subtitles with the correct timecode. Its up to you how you do your coding to get it to display, and what colours your want mapped to each subtitle mask colour. Of course, you can change each different maps colours too.
Hope this gets you started anyway.Some people are only alive because it may be illegal to kill them
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 06:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 00:22
