Hi!
A friend of mine has a JVC GR-D33UB, digital cam. THis cam has Firewire, S-Video and A/V output.
However, her computer doesn't have firewire port.
How can she connect? I guess I could buy a PCI board with firewire ports. But I talked to JVC support, but they told it wouldn't work, and that I should buy a capture board (just like a Pinnacle's). I thought it strange.
Can anyone help me please?![]()
Thanks.
Best regards,
Joelson. -
Thanks Richard!
Does that REALLY work?? Even for a JVC?
Has anyone ever tested this kind of cam, to find out if it effectively works with a cheap PCI board with Firewire ports?
Thanks again!Best regards,
Joelson. -
Yes. It will definitely work (even for a JVC). Please do not always believe the people in the support department. Usually they are novices.
My friend has a JVC GR-D73 but basically the technique is the same. As suggested you friend will need a 1394/Firewire card. She should get any cheap one such as from ADS, SiiG, etc. She will also need a 4-pin to 6-pin 1394/Firewire cable.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
SVCD2DVD on computer without internet connection
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 14th May 2009, 18:03 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23 -
JVC GZ-MG130U HD to computer issues
By 1n354a in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2007, 23:56 -
HELP! My computer isn't reading my JVC camera from the DV cable
By ninjacheese in forum Capturing and VCRReplies: 4Last Post: 3rd Nov 2007, 10:23 -
Panasonic PV–GS19 firewire connection - computer can't read it
By rbenjamin in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2007, 10:48
