ill tell u what im trying to make. im making 2 mpg's(dvd format) with TMPGEnc, then i want to make mpg 1 fade into mpg 2. what program can i do this with?
Results 1 to 9 of 9
im trying to blend a seen form a movie into another seen. like when a seen ends it starts to fade to black then it fades out for black to the next seen. do u know what i mean?Originally Posted by Nelson9937955
im doing a director's cut of a movie -
Get Womble Video Wizard and you are all set. It is a superb frame-accurate MPEG/VOB cutter, it has a variety of fade in/out options and 3D transition effects, it is fast and reliable, and - best of all - it reencodes (if needed) only those portions of mpeg/vob file you have altered by adding visoal effects etc.. Otherwise, your edited video output is generated without any alterations.
What more can you ask for. -
is Womble Video Wizard freeware? if i have any more questions ill post backOriginally Posted by zagortenej
do u have this program (mpeg video wizard)?Originally Posted by zagortenej
if so were can i get a tutorial on how to do what i said above^? i have never used this program before any help would be greatim trying to blend a seen form a movie into another seen. like when a seen ends it starts to fade to black then it fades out for black to the next seen. do u know what i mean?
You can download fully functional 30-day demo and give it a try:
http://www.womble.com/download.htm
The program is very intuitive and you should have no (major) problems figuring out how to do what you want. All transition effects are pre-set for you so it is for the most part a matter of drag-and-drop. You can, ofcourse, tweak fairly easily any thansition effect to your liking.
Which program I should use for video editing?
By Shigatsu in forum Newbie / General discussionsReplies: 3Last Post: 15th Jun 2011, 12:09 -
Best Editing Program
By deanmcdonagh in forum EditingReplies: 1Last Post: 9th Dec 2009, 10:21 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
The best program for editing?
By FredAstair in forum Newbie / General discussionsReplies: 21Last Post: 17th Dec 2008, 13:04 -
vidoe editing program
By romik91 in forum Video ConversionReplies: 15Last Post: 24th Aug 2007, 22:24
