Hey..
i can see there are a button there stands best on ? do that have something to say when i push that button when i make avi to dvd ? can see that the framerate changes a little ?
By the way, how can you make chapters in a avi to dvd ?
Crelle..
Results 1 to 12 of 12
It is a good idea, and normally it is "virtually" pushed by itself each time you open a file or choose a preset. However if you for example change the image size manually, you may want to click it again to recalculate the bitrate suited to the new image size.
To make a DVD from two AVIs the best is to encode each separately, and then import the m2v/ac3 pairs into Sizzle to author a single DVD.
thanks again
Somebody who knows how this sizzle program works ? can't realy see how to join the two video_ts
You should import in Sizzle the m2v/ac3 pairs to create titles (not the VIDEO_TS folders) and then you can create a single VIDEO_TS folder containing all the imported titles.
edit bluray button
By pcb in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2010, 22:29 -
First Unread button
By olyteddy in forum FeedbackReplies: 3Last Post: 21st Mar 2010, 15:12 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 07:04 -
How to disable a DVD button?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 17:27 -
no controll button
By moshe1980 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2009, 04:27
because, i would realy like to use
I just burn 2 dvd's then.. no problem..
