Is it correct for a DVD-RAM disk to become read only once files have been wriiten to it (drag & drop)?
I'm using XPHome and latest InCD but it looks as though I can still write files to the disk but I can't move the files or delete the. The properties always sshows them as being read only and if I try to remove the read only setting it still won't allow me access. I thought DVD-RAM would be like a DVD_RW?
THanks.
DVD-RAM is like a hard drive, you should be able to delete files. I had problems with InCD and DVD-RAM, you might try another program. XP is RAM compatible, try just using windows.
I had tons of trouble with InCD locking me out of RAM files and folders, especially those created on other machines not using InCD. I could not get around it by unloading the program, I also had to uninstall it.
Still a few bugs in the system... -
Strongly recommend avoiding InCD.
I routinely remove it on customers machines.
Incompatibilities with other software, incompatible disks, numerous problems.
Bad software.
Future of DVD-RAM?
By JamesGT in forum MediaReplies: 25Last Post: 28th Sep 2015, 19:23 -
DVD-RAM to AVI.
By aliciac in forum Video ConversionReplies: 16Last Post: 1st Apr 2011, 14:29 -
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 18:49 -
avoid Ahead/Nero's InCD like the plague
By JohnnyBob in forum Newbie / General discussionsReplies: 14Last Post: 14th Feb 2008, 15:58 -
What's wrong with this DVD-RAM?
By Shengton in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 09:27
