Im capturing analog video from VHS and creating a DVD from it. The sound on the VHS is not good, so I want to use my own MP3 files for the DVD's audio.
I am planning to use Adobe Premiere to create my DVD. My question is should I convert my MP3 to MP2 or WAV (since these are the 2 DVD-compliant audio format)? Which format is better quality-wise? Or does Premiere allow me to directly use the MP3 format as an audio track for the DVD?
Neither. Convert it to AC3 in ffmpeggui to be compliant for DVD, or at least mp2. MP2 and wav are not dvd spec, although many players recognize the format.
Does Premiere do AC3? If so, that's your best option.Cheers, Jim
My DVDLab Guides -
Not quite true... MP2 is not part of the NTSC DVD spec, but it is in the PAL DVD spec. As for WAV, that's in both (it's PCM uncompressed audio).Originally Posted by reboot
Yes, I believe it supports audio in AC3 format (i.e. adding audio that's in AC3). As far as I know, it doesn't encode to AC3. But I use Premiere 6.0 and I'm not sure what's in later versions.Originally Posted by rebootThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
creating an audio track for a custom DVD.
By fred3f in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2011, 06:42 -
Creating MP3 audio files from MP4 videos
By Kiwi999 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2011, 05:16 -
MKV to AVCHD - problem with MP3 audio track?
By magnu in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Nov 2009, 07:25 -
Creating a DVD from a MKV file and retaining all the audio tracks
By TioSolid in forum Video ConversionReplies: 7Last Post: 8th Aug 2008, 08:06 -
DVD concert audio to MP3 (Individual Track Please)
By c1steady in forum AudioReplies: 8Last Post: 11th Apr 2008, 14:19
