I'm trying to use GoldWave to reduce the hiss/hum of an SVCD, but when I load the mpg it says: "Cannot determine file format" and asks me to select from a dropdown list. But, i dunno which one to pick. Also, can I just open the .bin file with GoldWave, or do i have to extract the mpg first?
Any help would be greatly appreciated.
K, but the main question was what do I select for the file format? It gives me a list of raw sound formats like PCM signed 8-bit little endian, etc etc. I have no idea what to choose.Originally Posted by johns0
Well for File Type it gives me 2 choices 1) Raw (snd, raw) or 2) Dialogic (vox). For attributes it has PCM signed 16 bit, little endian, stereo...and all kinds of variations in the bits, stereo/mono, etc. And finally there's Rate (Hz) and by default it's set to 8000.Originally Posted by reboot
Can you be a little more specific on what I should select? And is this always the same for an SVCD, doesn't it vary based on how it was encoded?
In a different thread someone told me I should first extract the audio, then run that through Goldwave and then merge it back. But then in other forums I've seen people say they ran the actual avi file or mpg directly into GoldWave. So I'm confused. -
Open the avi in goldwave.
Select Effect, Filter, Noise Reduction.
In the little dropdown box, select Hiss Remove.
Click OK.
Wait a few seconds.
Click File, Save as, .wav, signed 16 bit PCM.
Now you can do whatever you want with the .wav to make a new SVCD (or whatever).Cheers, Jim
My DVDLab Guides -
It's not an avi, it's the MPG (AVSEQ01.MPG) that I pulled from the mounted .bin of the SVCD. When I open it up in Goldwave, it immediately pops up a window prompting me for the file format info I mentioned above. I know how to do the noise reduction etc after I get it opened. My whole problem is when I first open it, and also I do not think it's automatically pulling the audio from the file...because I selected a random PCM file format, did my noise modifications, and then did Save As, and the file was no longer playable.Originally Posted by reboot
Demux the mpg into an m2v and an mp2 using TMPGEnc Plus or TMPGEnc MPEG Editor, then open just the audio mp2 file in GoldWave. GW will recognise that perfectly alright and not ask you any other stupid questions.
goldwave help
By natty in forum Newbie / General discussionsReplies: 12Last Post: 14th Jun 2008, 01:28 -
goldwave help
By natty in forum Newbie / General discussionsReplies: 16Last Post: 23rd Feb 2008, 02:12 -
goldwave
By natty in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2008, 05:25 -
goldwave and wav codec
By natty in forum Video ConversionReplies: 4Last Post: 15th Jun 2007, 07:57 -
looping a track with Goldwave
By thecrock in forum AudioReplies: 2Last Post: 1st Jun 2007, 22:59
