Hello,
Considering I'm an absolute idiot regarding computers I have this question: When you purchase a new/replacement/external DVD burner, and the specs come out as being "Windoze X/P, etc". What is a Mac person to do with this hardware? Can it/they still be used with a Mac? I've been hesitant for quite some time, and have never really gotten an answer to this question.
My thanks,
Drake
Stick it in a firewire box and enjoy.
I've had a number of burners that only claimed XP support, but once I stuck it in a Firewire box, worked perfectly.
Just give it a try. If it works, keep it, if not, return it and try the next one in line. -
Anymore, the Windows statement on the box just means the bundled software is Windows-only. However, there are some drives that are better supported in Macs than other drives. You can read user reports for specific drives at the drive compatibility database at http://xlr8yourmac.com.
If you're considering a DL drive, I've read that the NEC and Pioneer models are performing better than the Sony. -
Right
I bought a Pioneer 108 which has windows plastered all over it. Like TGPO said it just means it comes with windows crap software.
Slap it in, or put it in an enclosure, and watch the magic of a mac occur
You may need to run PatchBurn3 to get iApp support but it will work
Happy burner shopping
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 18:14 -
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 17:01 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 18:27 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 21:53 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07
I feel better now.
