Using a HAUPPAUGE pvr 250 to capture vhs to dvd (home movies of kids) anyway they are 3 hours long so i captured @ dvd standard play which i believe to be best if im putting end product on dvd..
My problem is 3 hours turns out @9.4gig so i use nanoPEG EDITOR to clip bits but its very difficult to judge how much as there is no size bars etc also what i have clipped i need also to put on other dvd,s
Is there a similur\better program for doing this
Is there a way the capture will break it up into 4.37 auto leaving the other part so i can then use it with other leftover bits to make another dvd..
BTW i like the simplicity of nanoPEG
New to Was Editor
By HoosierGuy in forum EditingReplies: 5Last Post: 23rd Jan 2011, 18:52 -
editor switch?
By azfarhus in forum EditingReplies: 10Last Post: 20th Dec 2010, 14:08 -
Best PDF Editor..
By Soccerman77 in forum ComputerReplies: 1Last Post: 4th Nov 2010, 20:50 -
DV Editor
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th Sep 2008, 13:43 -
Codec problem (maybe) -- Hauppauge & nanoPEG editor
By SpaceCowboy9 in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2008, 11:49
