  1. I have a widescreen TV that I watch all my movies on but I also sometimes watch on a regular 4:3 TV. I have 16 x 9 AVI clips that I convert to DVD. To make them play fullscreen on my widescreen I have been using the crop funtion in TMPGENC Plus. The program I use for conversion. Is there a diffrence by using V DUb to crop AVI or by using TMPGENC? I want to make sure I am not doing anything wrong that I don't know about. I also want to make sure when I play the converted clip on a 4:3 TV, that it will be letterboxed. Thanks
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    In my opinion, you should leave them uncropped. Rescaling and recompressing will reduce picture quality.
    Get a DVD player that zoom scales the playback image if you want to fit the screen vertically.
  3. Well I have a DVD player with zoom but to me it looks better when cropping is done before encoding. So does anyone know what diffrence would be with v dub cropping as opposed to using TMPGENC to crop avi?
    Apr 2004
    Miskatonic U
    Absolutely no difference. It might even be slightly slower. A quicker solution might be avisynth, assuming it's crop function is faster than tmpgenc's in-built one.
    Have you tried setting your DVD to play back P&S. This will be much better than zoom mode, but should have the same net effect.
    Read my blog here.
  5. Thanks Gunslinger, I haven't tried setting up my DVD player that way so maybe I will check that out
