    Feb 2001
    Hey. I've got this wierd problem.
    I use TSCV to make VCD menus and chapters, I create everything allright, and I test the menu, and then I create the cue/bin files.
    Then, I load the cuesheet into cdrwin and burn it.
    Well it sure isn't a VCD. The damn program burns it as if it was an audio CD!
    When I look at the cd-r in my cdrom, it says audio-cd.
    What am I doing wrong here? anything obvious?
  2. Out of curiasity, why didn't you use TSCV to burn ? it has the buildin CDRDao support, and burns pretty great, even on my PC.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Feb 2001
    Didn't work. I don't know if it has something to do with my writer, or that I use XP. It just didn't work...
  4. XP strikes back, and people tell me OS/2 has low compatibility! Do you happen to even have an ASPI Layer working in XP ? If you dont, it would explain the problems.
    Best Regards,
    Sefy Levy,
