Results 1 to 11 of 11
  1. OK... I have searched for any info on this and I can not find it anywhere...
    I want to be able to RIP the audio tracks off my
    DOORS L.A. Woman DVD-Audio Disk...
    Then Convert them into MP3 files...
    Is there a tutorial or a simple software that will do this for me?
    THanks
    Nidaros
  2. Member Kurt S's Avatar
    Jan 2003
    A couple of good ones are
    ImToo DVD Audio Ripper - http://www.imtoo.com/dvd-audio-ripper.html
    DVD Audio Extractor - http://www.castudio.org/dvdaudioextractor/
  3. Do you mean DVD-AUDIO or DVD-VIDEO?DVDDecrypter->ISO read will tell you.
    If DVD-AUDIO,you can't rip it because it uses CSS2 encryption.
    If DVD-VIDEO use the ones listed above.
    You can however play the DVD-AUDIO with PowerDVD and record analog with Audacity then convert to MP3(not great but it works ).
  4. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    the first post on the audio forum
    https://www.videohelp.com/forum/viewforum.php?f=33
  5. OK...
    THIS IS NOT A MOVIE TYPE DISK!!!!!!!!!!!!
    DVD-A DVD-AUDIO
    THIS DISK DOES NOT HAVE ANY VIDEO ON IT!!!!!!!
    now that we are all on the same page...
    This type of disk is only audio DTS or Dolby 5.1 sound quality...
    Apparently no one has ever tried this so, I doubt there is an answer to my question...
    To find out more of what I am talking about go here...
    http://www.dvdempire.com/index.asp?userid=99364081262086&site_id=12
    Thanks anyway...
    Nidaros
  6. hmm... Thanks for the reply... however the software description clearly states that it is designed for DVD-Video type disk only...
    DVD Audio Extractor v3.1.0
    DVD Audio Extractor is a powerful software DVD audio extracting / ripping tool. It can help you to extract audio streams from your favorite DVDs and save them as OGG, MP3 or Wave files. DVD Audio Extractor can also demux audio streams directly to pcm, mpa, ac3 or dts files.
    DVD Audio Extractor features on its easy-to-use interface, ultra-fast extracting speed, multiple audio formats support, multi-channel support, resample to arbitrary sample rate, audio preview and much more. It's all what you needed to get audios out of DVD-Video discs, so that you can listen on MP3 Player, play on PC, record to CD or do anything else.
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    If you look in the 2 folders on the disc are there files in both the VIDEO_TS & AUDIO_TS folders ??
    Because most of the time there will be the same audio in both folders to be able to play in both standard dvd players and dvd players that support DVD-AUDIO.
  8. @nidaros,
    DID YOU READ MY FIRST POST?
    "If DVD-AUDIO,you can't rip it because it uses CSS2 encryption."
  9. Banned
    Jun 2004
    But if there are files in the VIDEO_TS folders then it is prob. the same song list as whats in the AUDIO_TS folder in which case he CAN rip it to his HDD and convert it and burn it to a cd as i have done with alot of my DVD AUDIO disc's.....
    That's why i asked him if he had files in both folders on his DVD AUDIO disc 8)
  10. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Many DVD Audio disks are hybrid, meaning as well as containing DVD Audio content (uses CPRM Protection at 128 bit) it will also contain DVD Video (not movie) content in form of audio in Dolby and DTS.
    The Dolby/DTS part of the disc can be ripped, but not the DVD Audio part.
