  1. Hi
    First off this software comes highly recommended by friends so I donated and installed error free but hit a snag and route to my first conversion.
    I am not sure but I renamed the files I want to convert so they got no Hyphen in them but I get this message.
    Any advice greatly appreciated .... AJ
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    Xceed.FileSystem.ItemAlreadyExistsException: Cannot perform the requested operation on an item that exists.
    Type: Xceed.FileSystem.DiskFolder
    FullName: D:\FTP\1 CATB VCD-SVCD\
    at Xceed.FileSystem.FileSystemItem.set_Name(String value)
    at _2b02761aea07325e.x210ff09a2516b1a7.xe539963764b40 d25(String x8dd66a714110d48d)
    at _2b02761aea07325e.x210ff09a2516b1a7.x60f18f1e09a87 437(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 1.51.2.0
    Win32 Version: 1.51.2.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    RegistrationSDK
    Assembly Version: 1.0.1608.40231
    Win32 Version: 1.0.1608.40231
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/RegistrationSDK.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Security
    CodeBase: file:///c:/windows/assembly/gac/system.security/1.0.5000.0__b03f5f7f11d50a3a/system.security.dll
    InProgress
    Assembly Version: 1.5.0.0
    Win32 Version: 1.5.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/InProgress.DLL
    MagicLocalLibrary
    Assembly Version: 1.7.4.0
    Win32 Version: 1.7.4.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/MagicLocalLibrary.DLL
    FolderBrowser
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/FolderBrowser.DLL
    AxInterop.SHDocVw
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/AxInterop.SHDocVw.DLL
    DevComponents.DotNetBar
    Assembly Version: 4.6.0.0
    Win32 Version: 4.6.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/AxInterop.CodeLock.DLL
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Interop.CodeLock.DLL
    Interop.SHDocVw
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Interop.SHDocVw.DLL
    Xceed.FileSystem
    Assembly Version: 1.0.29.0
    Win32 Version: 1.0.29.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Xceed.FileSystem.DLL
    SVCD2DVD.HelperUpdates2
    Assembly Version: 1.0.1806.19400
    Win32 Version: 1.0.1806.19400
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.HelperUpdates2.DLL
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.HelperUpdates.DLL
    SVCD2DVD.VCDGear
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.VCDGear.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. Doh I had missed an obvious hyphen !!
    feel like a right noob !!
    Thanks for looking in anyway !
    AJ
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Hi,
    You were nearly there! The hypen in the path : "1 CATB VCD-SVCD" is causing the problem. Can you rename the folder or move the files to another folder without a hyphen... Or use v2
  4. The previous posts in this thread have me confused.
    I have been using hyphens [ minus sign characters] in lots of my filenames and in parent folder names forever with RC2, RC5 under XP Home,
    without any problem.
    If hyphens are not allowed, I blissfully missed that rule.
    An explanation of any "no-hyphen-rule" vis-a-vis my experience would be most welcome.
    Cheers, P-PA
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    hyphens are no problem in v2.x
    They are sometimes an issue in v1.52....
    From the error log OP is talking about the latter:
    SVCD2DVD
  6. Thanks CB.
    Ppl still using 1.5x...?...
    Shhhhheeeeeeeeeeeessshhh !
