can someone point me in the right direction as to how to put the avi, divx and xvid files i have on hd to dvd, what tools and giudes would be easier to work from, thanks guy's again.
Results 1 to 11 of 11
I demux the audio to .wav in VirtualdubMod, then Convert it to .ac3 in ffmpeggui. Encode the .avi in Canopus ProCoder to Mpeg2. Then Author the .m2v and .ac3 in a dvd authoring program like DVDAuthorGui. Then burn in Nero.
Here's one way: http://members.shaw.ca/videojunk/avi2dvd.htm
Cheers, Jim
My DVDLab Guides -
wow take it steady reboot, lol, my brains frying here looking at that guide.
LOL. That's one way.
Here's a list of other ways:
http://members.shaw.ca/videojunk/all.htmCheers, Jim
My DVDLab Guides -
I concur with Reboots list of other ways. I have used The Film Machine, D.I.K.O., and VSO DIVXtoDVD which are all free! They are very easy to use and guides are available. I have been satisfied with the results but if you are very critical then you should use multiple programs (TMPGENC, DVDAuthor, etc.) to get your results. The ones I use do all of the steps in one program.
i tested a couple of the tools and 1 created a ton of god knows what on my desktop and another 1 wanted to create a bin & cue my dvd player doesn't play iso files, still puzzled and need to know coz i'm getting a dvd burner very shortly. H E L P.
alright the quick, quick version!!!!
get a hold of tmpeg, install & run, it should auto start a wizard, select the dvd you want (pal/ntsc- read the descriptions!!! too) & select the vid, you know the story click next a few times & it will start encoding. done!!!
you now got a dvd mpeg video file...
get a hold of TDA (tempeg dvd auth), open that & create a dvd & menu. bunr using its bunner..
if your drive don't support TDAs burner save the files to disk & burn a 'video dvd' with the software that came with the drive!!!!
note you might want a ntsf hhd partion if your mpg's gona be more than 4 gigs.COOKIEEE!!! -
cheers dude, but the audio isn't supported in tmpgenc for any ac3 files so are you saying to demux in virtualdub mod and add the ac3 file from dvd author.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
