Hey.
anyone recommend on any method ? I saw many guides around here , and I was confused , dunno which one to test .. btw , I wanna also add subtitles ... anyone can Help please ?
Thanks all. :P
dvd2svcd, you can add swithable subs.
https://www.videohelp.com/guides.php?guideid=603#603 (instead of avi source select dvd source) -
It's been a while since I've used it, but use the SVCD compatible setting for subtitles in dvd2svcd. Almost nothing supports CVD subtitles. Some standalone DVD players won't play any format subtitles in SVCD, others like the Philips DVP-642 will do weird things like only play the first subtitle it finds and not allow you to turn it off or choose another subtitle stream
Finally, when I used to make SVCDs, I had some weird problems where if I tried to burn a BIN/CUE image, I could not get my Apex DVD player to recognize the subtitles at all. However, if I burned the video file that had subtitles muxed in using the SVCD template in Nero and not the BIN/CUE file, it would play the subtitles fine. The downside of using Nero is that you can't set entry points (chapters) with it, but dvd2svcd creates them in BIN/CUE images. So I had a problem where I could either have working entry points or working subtitles, but not bothThat problem may be specific to my old Apex player, so I'm just mentioning it as a possible problem you may (or may not) see.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
problem converting from NTSC VHS to dvdr
By skywalker9999 in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 04:22 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
