  1. I have a Win XP with service pack 2, windows media 10 and power dvd...when I was
    playing a dvdr , the windows media started ...and the power dvd also !!!...
    windows media try of read the disc...but can't read...so I close the windows media and
    I open the dvd with power dvd...the movie start but the dvd rom make noise..
    ...maybe have a discalibration (I guess)...Now , when I play a dvdr with games or movies
    make the same noises in the dvd player...
    The dvd rom player is LG (11 months old)...I was playing a dvdr Fuji...
    I know the service pack 2 make a change in the controlers of the dvd...
    Could someone,please,tell me if I must change to service pack 1 for resolve the problem
    of noise ?
  2. Banned
    Oct 2003
    Americas
    You have 1 month to decide whether to return/exchange LG drive. Use it wisely.
    Service packs have nothing to do with your DVD player's noise (to my knowledge). Test on diff. apps and decide. Abnormal noise is not a good sign whatever app you use.
  3. Hello again...
    I received a dvd-r show in a trade (brand: fuji) and when I played in the dvd rom
    player LG of my brother...this maked a rare sound just like the player "trembled" ...
    so I was played others dvds later of that and happen the same ...(branded or no-branded,dvdrs or silver pressed)
    So I sent the dvd rom player to the tech service of LG (the dvd rom player have 11 month of use)
    The tech service tell me that something could be happen in the rotation of the motor...
    and it's possible LG change the dvd rom player for a new one...
    (but the tech service will confirmed this after of a complete revision)
    I'll buy a dvd burner LG for me...for burning and for play dvds...
    A question,please:How I can prevent all this problems ? I always receive dvds in trades
    and it's obvious that the disc dvd that I played was the guilty of all this problem..
    Thanks in advance
  4. Mod Neophyte redwudz's Avatar
    USA
    Did the disc have a label? That can cause vibrations. You should take a look at the discs before you play them. A badly out of balance disk could damage a player, but most of them will shut down quickly if they can't read the disc.
  5. Banned
    Oct 2003
    Americas
    One of my DVD's has caused the laser pickup to overheat and as a result the pickup had to be replaced. Played all but this disk (it worked but stumbled, froze DVD plaer etc.). After the replacement I was able to play the same disc without problems. I guess it helped the potential future problem to surface much earlier then it normally would. Things happen.
  6. Thanks for the replies ....
    proxyx : No ,none of the dvd discs that I was played have a label ....
    please,could you tell me how can I recognize a dvd disc “out of balance” ?
    in wednesday I received one dvd disc with a label ...
    please...how can I know if one dvd disc with label can damage a dvd rom player ?
    maybe checking the edges of the disc ?
    (if exist some are where the label don’t be stick in good form) well this disc seems just like be stick very well ...
    redbudz: The disc dvds also can cause overheat in the laser ?
    please ,how can prevent this ?
  7. Banned
    Oct 2003
    Americas
    It all boils down to playability. If it's OK, no strange noises, vibrations and freez-ups - leave it alone. Never used labels and don't plan to. This is just asking for trouble. I leave the disk as it was manufactured.
    "The disc dvds also can cause overheat in the laser ? please ,how can prevent this ?"
    I can't tell, I guess when it dies on you you'll find out.
