Hi,
Do i have to make all my avi's "there are NTSC" to PAL ? allmost any dvd player today can play both, right ?
And if the subtitle, is a NTSC, and you make the dvd to a pal, then the subtitle don fit ? right ?
Crelle..
For who do you make the DVD? If it's just for yourself, then it only matters if your player handles NTSC discs. If you make the DVD for unknown player X, then you can't be so sure it will play alright.
Just about all players sold in PAL regions will play both PAL and NTSC, but most players sold in NTSC regions will not play PAL. Some players send the signal predefined, some players convert the signal partially, some convert the signal fully. So, if the player handles the disc, that does not automaticly mean that the tv will handle the signal.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
