  1. Can someone help me solve this issue? I am creating a custom karoke dvd from alot of different vcd karaoke. I convert the mpeg1 to mpeg2 and audio to dvd ac3. I have 30 songs, 30 movies. I am having trouble creating chapter to jump around the dvd. If I join the movie and audio together, the audio go off sync. Anyone know the secret to doing chapter for mult movie file in dvd-lab pro? Or recommand an editing software that handle mpeg and ac3 at the same time?
    TMPGenc dvd - always mess up on song 17 but dvd-lab pro doesn't and TMPGenc dvd doesn't let me have mult audio track.
    whatever86
  2. Set your chapter points at the END of each clip, not the beginning, as you'd think. Then you can jump around as you should.
    Your other option is to not use chapters, just use normal links from a menu structure.
    Cheers, Jim
    My DVDLab Guides
  3. Reboot,
    I'll try it out. thanks.
    Whatever86
  4. I also want to put my karaoke vcd to karaoke dvd. Of course I want to keep the karaoke feature on dvd so I can turn off vocal when I want to. Can you post a tutorial on how to do this and what software I will need to use? Thanks.
  5. Hi Minh
    It took me over 2 week of research create a karaoke from DVD and VCD and i learn that this site have all the info but you just have to read alot of tutorial. I use cooledit to edit/create the voice and non voice. DVD-lab pro let me create mult audio channel DVD to switch between voice and non voice. I don't know if the other newer software let you do it the mult audio channel.
    Whatever86
