I would to buy a firewire card, but confusing to choose it. I found Some have 2, some have 3, and some have 4 connectors.
Any suggestion for firewire spesification ? Some are recommended with TI chips...Any Idea ?
Thank you
Ngurah Agung
www.artinicottage.com
Results 1 to 10 of 10
nas pengeng de ngendah
If you want to connect 4 Firewire devices at the same time, you'll need a card with 4 connectors. If you only want to connect a camcorder, you'll only need one connector and the others will be spare. TI chipset cards seem to have best compatibility.
in my experience, I was not able to use NEC based FW1394 PCMCIA (see previous post). THe VIA based worked only for me wtih XM-2.
Sasha -
get a ADAPTEC FIREWIRE CARD which i have in all my pcs. i have no compatibility issues at all.
I've had experiences with FireWire cards, two had VIA chipsets (one built-in on an Abit motherboard, one PCI card), and two had TI chipsets (one built-in on a Gigabyte mobo, one ADSTech Pyro Pro PCI card). Of the three camcorders I tested (Sony D8 TRV-350 & TRV-950, and Panasonic NV-DS28), ALL the TI chipset-based FireWire detected and properly controlled them (w Premiere Pro); the built-in VIA on the Abit mobo flat out refused to detect/connect ANY of the camcorders, while the VIA PCI card detected the two Sonys but not the Panasonic and even then sometimes simply stopped capturing and other behaviours simply not present using the same test bed as with the ADSTech card. SO, whatever FireWire card that is, strive to get that with a Texas Instruments chipset.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Same here, budz! Adaptec duoConnect (2 Firewire, 3 USB2 ports). It has worked perfectly for me from Day One.Originally Posted by budz
(I run Win2K Pro). -
Newer Sound Blaster (creative labs) Audigy sound cards have built in firewire ports. My sisters Panasonic GS-120 works flawlessly with my Audigy 2. Although I have heard of some issues with camcorders.
The firewire ports built into my Abit NFS-7 revision 2.0 (via chipset) also work flawlessly with the GS-120.
I usually ctransfer with DVIO from Camcorder -> Audigy 2 firewire port -> built in firewire (via) -> external 160GB HD, without any problems.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 06:11 -
Expensive or cheap iLink/Firewire cable for video transfer?
By chin569 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Jun 2008, 12:37 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 02:19 -
best Firewire/ilink card for Sony Hdr-hc5e??
By BrohiBoy in forum Capturing and VCRReplies: 1Last Post: 17th Jan 2008, 02:07 -
need help on how to connect sony ilink to macbook on firewire 400
By sasuke85 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th May 2007, 00:50
