I don't know what happened.
I burned a movie fine yesterday and it didnt hint anything was wrong with my dvd burner.
The next day a put in a dvd, cdr, and blank dvd and it wont read any media I put in it.
I went to nero to do a test burn , and the error window poped up saying "theres no media in drive" which there was.
My dvd model is HL-DT-ST DVDRAM GSA-4082B
Any ideas how to fix this?
Try the burner in another pc,if its still the same then its hooped,if it works then its a problem with your ide drivers,use ms ide drivers if thats the case.
Remove it in device manager and reboot & let windows detect & reinstall the drivers then try it again before you go physically removing anything. It might just be a corrupted driver or something.
Have you tried to burn a CD? If it's like my situation a year ago, then I'll bet you can. That wouold mean that the DVD laser died. No warning seems to be given. In my case, I burned a DVD and about 15 minutes later tried another and BAM, no didk on the drive messages with every program I tried. Yet CDs would burn just fine. Solution??? A new burner.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Hmm, Do you think that happened in my case too;Originally Posted by jtoolman2000
https://www.videohelp.com/forum/viewtopic.php?t=261807
I ripped and burned a CD last night but didnt think it used a different laser for DVD reading.
Since I posted that I've been messing around no end with drivers etc. I did mull over downloading firmware, but cant find any specifically for my drive, pluse I have a 2nd dvdrom drive so didnt want to mess that up.
Was going to try a registry mechanic as a last resort tonight, just in case some software was causing the prob.
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 02:47 -
Why don't drives read HD-DVD anymore?
By Sephiroth666 in forum Blu-ray RippingReplies: 40Last Post: 10th Dec 2009, 18:48 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 23:18 -
My DVD drive wont record Deul Layer anymore.
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 11th Jun 2007, 16:07
