I shot a few AVI with my digital camera. The AVI files are 30 fps, 640x480 MJPEG. I use PICVideo decompressor.
I loaded the video into Premiere and did some quick cut. Then used "Export Movie" with the following setting (most of are default since I don't really know them)
File Type: Microsoft AVI
Video only
Embedding Options: Project
Codec: DivX Pro 5.2.1
Millions of colors
640 h 480 v
30.00 fps
Square pixel
Data Rate:
unchecked Limit Data Rate to
checked Recompress "Maintain Data Rate"
Deinterlace Video Footage
checked Optimize Stills
DivX codec is set to progressive source, Fast, 780 kbps, 1-pass
The result file is rather large, 271MB for 8min. This is about 4 mbps.
Worse, it is UNPLAYABLE. It will crash any WMP and VirtualDub. I got the following in VD:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'......while decompressing video frame 0 with "DivX Pro(tm) 5.2.1 Codec" [biCompression=30355844] (VideoSource.cpp:1772).
After fiddling around with deinterlace (set premiere to lower field first and DivX to deinteralce) and uncheck Recompress, now I get an AVI file that I can play. But with very low quality and large 4mbps.
I remember doing this some time before on smaller video (320x24) and it worked fine. Am I missing some settings?
Thanks!
Have you tried loading the source video (MJPEG) to VirtualDUB directly?
You can do the same editing there.
If VirtualDUB can open the file, then during conversion to DivX (saving) select:
Compression Speed = Slow, Encode in 1 pass quality based with a Q factor of 5~6, encoding progressive or interlaced, depending on the source - probably interlaced - and key frame every 100 frames.
If it is still too large, increase the Q factor until size becomes adequate while quality doesn't suffer.The more I learn, the more I come to realize how little it is I know.
Unable to encode whole video
By Egotomb in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 15:57 -
Handbrake unable to scan/load source video files.
By e6bwhiz in forum Video ConversionReplies: 1Last Post: 22nd Feb 2011, 17:44 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
In linux. how do I burn slideshow DVD from jpeg/mjpeg combo source?
By nidape in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 07:33 -
Divx/Mjpeg to Mpeg-4 with VirtualDub
By nalooti in forum Video ConversionReplies: 2Last Post: 16th Nov 2007, 23:50
