I'm Sure many people had this problem, but ya here i go anyway. I have the Video_TS on my computer, and when i open up Nero to burn it it comes up with the normal screen. then at the top corner i go to DVD and the whole computer just freezes. What is happening?
Go to http://www.expage.com/howtocopydvds4free it Rocks!
You didn't say, but I'm assuming you're using NeroVision. If that is the case:
I've found it helpful to save the project after making Video_TS... then restart Nero before burning. Otherwise, Nero freezes. Don't know why; it just does.
Then, I restart Nero and burn.
If you're using plain ol' Nero, it's likely something you're running a conflicting program in the background, (like an antivirus program, for example).
Other thread-readers may have different approaches; but you need to provide more information about your situation and computer system for them to help you, such as the version of Nero you're using, type of computer, amount of RAM, operating system, etc.You're never alone with schizophrenia. -
Sony Viao
2.0 GH P4
512 Ram
80 Gig HD
60 Gig HD
DVD RW
CD R
Not sure bout the brands, its the newest nero, like 6 i think, and I'm using the plain Nero.
But, Im still getting the same problem with CopyToDvd, i think its the computer becuase with every dvd burning tool it freezes.Go to http://www.expage.com/howtocopydvds4free it Rocks! -
actually i had this problem hopefully i can help out here,, the problem exists with the newest version of nerovision and specifically recode,,theres a file nendgui.dll thats causing the conflict if u rename this file the conflict goes away,, anyway this worked for me when i was having the problem,,once again its only for the latest version of nerovision 3.1
VCR Freezing
By koberulz in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2012, 22:40 -
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 14:52 -
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 21:37 -
ScenalyzerLive Freezing
By JoRodd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Mar 2009, 09:36 -
Freezing during transcoding in Nero Vision 4
By TheGMan in forum Video ConversionReplies: 2Last Post: 21st May 2008, 10:09
