hello!
I tried to burn a set of bup\ifo\vob files with Nero and it displayed this msg:
"The DVD-video files compliance test failed. The resulting DVD-video might be unplayable. Do you want to continue?"
what should I do please ?
thanks!
If you have a DVD-RW, you can try it out on that. They will most likely still work. How come you are missing some? Just whip them off the original DVD again. Sorted! 8)
What did you use to author?
Look in the VIDEO_TS folder,you should have at least one of:VIDEO_TS.IFO,VIDEO_TS.BUP,VTS_01_1.VOB,VTS_01_0 .IFO,VTS_01_0.BUP -
I have all the files MOVIEGEEK listed
maybe I should burn in nero as DVD-ROM(UDF\ISO) or something else ?
I dont know the authoring tool, how can I find it ?
is there something I can do that will make it playable to all DVD players ? (including my DVD-RW and DVD standalone player)
thanks!
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 02:13 -
Titlewriter 4.65 disc compliance failed ....... Fallen Angle please see me
By Devoir in forum Authoring (DVD)Replies: 22Last Post: 15th Mar 2010, 10:49 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 02:10 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 02:15 -
DVDReMakePro - Nero compliance error?
By Sephiroth666 in forum DVD RippingReplies: 7Last Post: 1st Dec 2007, 10:15
