MSU deblocking 2.1 for VirtualDub released!
Main advantages:
* Now work with high resolutions.
* Non SSE old processors now supported.
http://www.compression.ru/video/deblocking/index_en.html
Enjoy!![]()
With regards
Dmitriy Vatolin
http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
Senior editor of Compression-links.info -
Great. You guys are great. Always speeding things up
BTW, do you know if the deinterlace filter will ever be released?
So wheres the link for 2.1? The "Unpack this file in the folder "Plugins" in VirtualDub directory.File size 72 KB (in ZIP)" link gives you 2.0.
You guys are something man. Keep up the good work guys.When I was born I was so shocked that I could'nt speak for 18 months. -
I love this filter!
It's the only way to deal those macroblocks on DVB mpeg 2 broadcasts!La Linea by Osvaldo Cavandoli
Originally Posted by mh2360
yes - it appears to be the wrong version packed into the zip - only the html file is diff."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
Big thanks to SatStorm, sanjayk and hrlslcbr for warm words!With regards
Dmitriy Vatolin
thanks DmitriyV (i also like these filters a lot)
will check it out now .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
H264 in-loop deblocking filter, a good thing?
By deadrats in forum Video ConversionReplies: 1Last Post: 12th Feb 2012, 20:48 -
MSU Old Color Restoration alternative?
By magillagorilla in forum RestorationReplies: 55Last Post: 30th Jul 2011, 12:30 -
How to keep ffdshow post processing(deblocking filter) in finalized video
By Milardo in forum EditingReplies: 6Last Post: 5th Apr 2011, 05:09 -
8mm film and the msu old color restoration filter
By buckethead in forum RestorationReplies: 14Last Post: 22nd Jul 2009, 23:06 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17
