Why is it that i cant read a dvd backup in the same drive i backed up the original one. But i can view the dvd in the player without a problem
Might it be the media type? Im using dvd+r
Im planning to do a copy from a backup, do someone know how to correct the problem?
thanks
Yes, switch to DVD-R's.
Apple's DVD Player software is coded
to not recognize DVD+R discs.
This has been covered numerous times
on Apple's own support forums.
if you continue to use DVD+R's, you might have to switch to VLC,
and play it by navigating onto the disc and opening the VIDEO_TS folder. -
In my case that's inaccurate information (or I'm lucky
). To double-check, I just ran a couple tests:
DVD Player (version 4.0; OS X 10.3.8; iMac G5) has no trouble playing a movie I created with iMovie and burned to a Ritek DVD+R with iDVD a couple weeks ago. It also plays a DVD+R backup of a DVD extras disk burned (on my eMac) with Toast. Standard Apple drives: Matshita UJ-825 (lame) in the iMac; Pioneer DVR-107D (good) in the eMac.
I normally use DVD-R/RW, though. -
Yup, your definitely in the minority:
http://discussions.info.apple.com/webx?13@912.bagQaigySss.1@.68a41eff/10
iMac G5's have the limitation removed from them
( also known as Apple's "crippleware") that
prevents
earlier mac models ( ie G4 based Macs)
from burning/reading to DVD+Rs.
apple removed the stipulation starting with the -107 models
it shipped in machines, so it's no surprise that your emac
is also blessed.
count yourself lucky."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I can't really follow what that Apple Discussions thread is supposed to be saying so I'll just be satisfied that the media I'm using is compatible (enough) with my software/systems/burners.
basically it says what I said above....
Urban Mac User
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 08:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 00:50 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 09:30 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 08:38 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
