Hi!
A friend of mine has a digital cam, model JVC gr-d33.
She wants to connect her cam to the computer, but there isn't a firewire port in her computer.
My question is: is there a Firewire-USB cable, so she can do this?
Thanks!![]()
Results 1 to 13 of 13
Best regards,
Joelson. -
Just buy a PCI card with a firewire port. They are not that expensive. You can't go from a firewire output to a USB input.
If such an animal existed, (it does not), you would not want one. Get the Firewire card.
A firewire card is the best option. But there are other options: https://www.videohelp.com/forum/viewtopic.php?t=269248
I just found a cable that will convert a firewire DV stream into an USB2 DV stream
Take a look: http://www.pixela-1.com/captycable/
*** EDIT: 4-AUG-2007 - Updated link *** -
A $130US price tag is a little steep, though. I could buy a quite a few PCI Firewire cards for that or even some PCMCIA Firewire cards.
Totally untested and not to be trusted.
Why spend $130 for this when a PCI card and cable can be had for $20 if you shop carefully.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I dont think it would be that cheap for use on a "Laptop". But very good point.Originally Posted by edDV
I wouldnt trust that it would work. "That Great". -
I got mine Firewire card from Walmart for only about $25.00.
Yes, they do make a combination USB/Firewire card. They have them at CompUSA.
I do prefer a PCI or cardbus card instead of this cable, but there are some systems out there with no expansion capabilities (like a Dell Optiplex SX270). For those systems a cable like the one in the link above is the only (and expensive) option.
I suppose it would have purposes like ofbarea mentions. It would be nice to be able to download a DV file to just any computer with a USB 2.0 port. Maybe if they sell a few and the price comes down to about $50US, it might find a niche.
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 12:59 -
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 14:05 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 12:28 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 21:01 -
Camcorder - Firewire to USB cable
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2007, 09:29
