I'm running OSX 10.2 and downloaded some public domain films in the mp4 format. The site gives the option of downloading MPEG-1 or 2 but being a novice I chose mp4 because of the smaller size. Can I expect a good quality DVD encode from my mp4s or do I need to re-download using one of the other MPEG options? Thanks!
depending on the format of the other options..
mpeg1 = probably vcd format, vhs-ish quality
mpeg2 = vhs to dvd quality, probably your best choice
you could convert the mp4 file to mpeg2 (which is what dvd uses), but you would lose quality along the way. you need to find the specs of the mpeg2 file, it may be svcd.. but if its dvd spec, then go for it.
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
mp4 to mpeg-1
By Jonahinthewhale in forum MacReplies: 21Last Post: 4th Sep 2009, 11:37 -
MP4 conversion to mpeg for DVD authoring
By npereira in forum Video ConversionReplies: 8Last Post: 2nd Jun 2009, 05:20 -
mp4 to mpeg/avi
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2008, 02:42
