hey all,
I'm looking for a good quality A/V selector that will allow me to switch between at least 4 component video sources.
I'm looking for something that is going to be well built and minimal signal loss/degredation, though I don't really think a signal amplifier is necessary. I really don't want to spend more than $100 to $150 USD.
So far, the only thing I've really been able to find is the JVC JX-S111. It doesn't look bad at all, but if any of you can either give me your comments on this unit or recommend a better one, I would be eternally grateful![]()
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Here's an inexpensive one.....
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=180-938 -
Already posted in here.
https://www.videohelp.com/forum/viewtopic.php?t=261381 -
shadow, that one doesn't do component video
i found these 2
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=353299&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=292714&is=REG
under the specifications tab, the JX-66 says "30MHz" video and the JX-S111 has "10MHz" video.
what the hell does that mean??
I'm leaning towards the JX-66 simply because it's a bit cheaper and still has the same number of component inputs.
any constructive/helpful input would be appreciated
i looked up the Pelican in the other thread that was referenced, apparently it's a piece of crap"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Ahhh.....I read it wrong.Originally Posted by Xylob the Destroyer
I read that as components, thinking VCR, DVD player, etc. -
nope, RGB style is what I'm lookin' for
Audio/Video multi format/source selector
By YesRushGen in forum DVB / IPTVReplies: 0Last Post: 14th Jan 2011, 19:06 -
Audio/Video Selector & Output Quality
By Tom Saurus in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2010, 17:27 -
Card for capturing HD Component Signal
By peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 10:42 -
Can you get hi-def component splitters or switch boxes?
By eggedd2k in forum DVB / IPTVReplies: 4Last Post: 7th Dec 2007, 10:10 -
Component video signal->TV problem
By nathanaa in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2007, 22:37
