Okay, so my roomate has a G5 and it has a DVD Writer made by Sony in it (yes it is the factory installed drive). I am converting downloaded TV Series Episodes from AVI to DVD format using WinAVI on my PC. And I am about to use TMPGEnc DVD Author to author a dvd and then I will transfer it to the MAC to burn it.
My question is, what program should I use to burn it(idvd, toast, disk utility), and with what settings should I use to make it the most compatable with standalone DVD players? My knowledge of MAC is limited and my roomate doesn't do much video authoring/burning.
Use Toast. Toast v6.0.7 and higher has an option called... "DVD from VIDEO_TS" which will take an existing authored DVD folder, automatically filter out any non-standard Mac OS files, add an empty AUDIO_TS folder for compatibility. Burn on high quality (brand name) blank media using DVD-R or DVD+R at 1x speed and you should be good to go.
For already authored content, I'd suggest Toast, which will take a VIDEO_TS folder, unlike the others.
Okay here's another cool question. I used WinAVI to convert from XVID to DVD (VIDEO_TS VOB's), but they turned out to be around 2.2GB per 40min episode. The quality is about the same as the origional XVID file, but at this rate I can only put 1-2 files per DVD.
What exactly am I doing wrong here? I want to put 15 tv episodes onto like at most 4-5 dvd's!!! -
Forget that question, I asked it in the appropriate forum section.
Thanks for the help. I'll definately use Toast to burn.
Epson p50 photo printer compatable cartridges
By Rogert in forum ComputerReplies: 0Last Post: 4th Aug 2011, 07:46 -
What Software is Compatable with X.V. Color?
By Jake Bernhard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Mar 2011, 22:15 -
Is QT Alternative 1.81 and 3.x compatable with Windows Vista SP2?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2010, 00:02 -
VOB & MPEG4 HD to Windows Media Compatable Format (DVD Quality?)
By RobsterNo1 in forum Video ConversionReplies: 2Last Post: 28th Oct 2008, 06:49 -
USB 2.0 hubs (backwards compatable)
By guitardan in forum ComputerReplies: 4Last Post: 25th May 2008, 10:01
