When burning a VCD from a DVD, is there any way (or tool) to keep the sound like in the DVD (5+1), not only stereo?.
<font size=-1>[ This Message was edited by: balki on 2001-12-10 08:39:52 ]</font>
I don't believe vcd is 5.1 capable, you need to make an svcd if you want this feature.
yeah, http://www.labdv.com is a good site for that...I think that you have to have Linux to do it...and even then I don't think that all players can play it...
therick, that is only available in svcds, not vcds and I think so far only philips dvd players have been shown to support it.
Nope vcd is only capable of cd quailty sound dvd quailty is way above that. However I have a dvd 2 vcd guide which will convert the dolby digital 2 dolby surround sound which I think sounds just as good in terms of where the sound is coming from and sound quailty isn't bad either.
Baker -
never said that is was for vcds...KDiddy and I posted at the same time...I was running on the last thing somersby said "you need to make an svcd if you want this feature."
Issues with Dolby Digital Sound (rear audio only for one chapter)
By ehmjay in forum MacReplies: 0Last Post: 20th Oct 2008, 09:55 -
Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2008, 23:32 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 14:53 -
How to edit multi audio dvd s ? (dts, dolby digital keeping both)
By live4fun in forum EditingReplies: 10Last Post: 3rd Jul 2007, 04:08 -
Does Divx contain the Dolby Digital and DTS sound.
By sam9s in forum DVD RippingReplies: 8Last Post: 11th May 2007, 15:37
